Replacing tracks on my st4
caribouhills17
I just bought a snow trac st4 from Brandon Sorrels in Kenai AK, and need to replace 1 set of tracks. My question is can I use 4 ply conveyor belting for the tracks. Any help would be great, Thanks:sad:
Well it depends on the belting. There is a working temperature range and streach factor from what I understand that should be considered. I think there are old posts on this here some where, maybe do a search on "snow trac track belting" or something similar. So just one side needs replaced?
mine has a heavyer 4 ply belt on it but i would rather have a strong 3 ply belt it will suck up less hp also replace the belting with what you all ready have on the other side or you may experiance pull caused by moor drag on one side than the other and the pdf is on the way
for those interested here is the lay out pattern in pdf for the 2 band track thank teladawg he was my sourse for the info
