pixie
People are rough on these machines.
My diffferential housing had a long rip in it that had been peened over and it was also rusty on the inside. It was only 1/16 metal to start with.
I took it to a local welder who did some frame work on my Imp a couple years ago. He is replacing the sides and bottom with 1/4 steel.The rest of the tub had already been covered with 5/16 steel before I got it and there is a 1/4" front belly plate that has the plow brackets on it.
First he cut out the front bogey axle which was shorter than the rear bogey axle. The new one will be the longer length. Then he got a pattern from the sides of the diff. Then he cut the sides out.
He has also cut the inner support beams free of the bottom but not from the front edge.
