JimVT
I scoured the bone yard today and found a 16inch donut tire and am going to cut the center out and weld it in place of the cast aluminum centers that are broken. the cast centers are riveted to the steel rims.
one broken wheel tire is foamed and not sure about the heat from welding. The other has a crack in the cast that you can see.
i'll need to get the offset correct and the bolt pattern matches fine.
