Got Home intact! GPS summary is always good data, I like to track the fuel burn and mileage. I was a little surprised at the max speed, I don't recall being much over 82ish cruise was set in and around 72 and 82 depending on speed limit.
Snow trac:
During the trip I Dumped some Diesel straight down the carb,*about a cup* I put some in the gas tank as well...
A random trucker was looking the machine over and saw the bee or hornet nest in the carb, I mentioned it was tight and most likely coming out, He said to try soaking the motor with diesel. Luckily the choke was shut before they built the condo, I picked it free and the wind blew it out nicely. at the next stop I asked
The attendant at the fuel service fuel stop to fill the motor He did not bat an eye and filled the motor......
Motor is showing signs of letting go, the sloshing around on the trailer really helped. I am going to pump some grease into which ever cyl is on the power stroke and see if the engine will turn before I yank it out. the motor was solid upon receipt, after the tow the crank is willing to try to move time to get the pistons to follow suit.....
