any body else have a gas powered bv206 i'm interested in how your idle quality is i am working on one now and it sounds as if its missing at idle runs good at higher rpm's and i don't know if the industreal engines have some kind of high lift and duration cam wich causes poor idle or if the europeon solex carb is causing problems i don't want to try to fix the carb if the engines camed too radicaly to idle properly.
