pb 240 reverse issue?
Travis
The right track moves real slow you have to hold the wheel to the lift to get it to go straight.
Any ideas?
High pressure rel.
Elec.
It goes foward just fine
Any help would be great
Need to groom this weekend
1995 240 d
I don't know much about PBs but they are hydraulic drive so I'd try reversing the lines and see if it was slow forward. Inside of line might have a bubble/flap.
Could also be a bad contact if it has elec. over hyd.
It is ele. Over hydro.
I think the drive load card is shot i know have to run it on bypass switch
Do you see these cards going out often
So if I understand you correctly the cat drives correctly in the bypass mode? I had to replace a drive card on my PB200D after driving a whole season in the bypass mode. The dealership replaced the analog one with a digital one on my PB260D even though that turned out not to be the problem. I have my old analog one which may work on your PB240D.
If you haven't already done so I would get ahold of Pisten Bully Tech services in Reno. I have their number some where if you can't find it by googling. The tech guys will walk you through a reset and email you the info you need to trouble shoot your cat.
Hey Travis, saw your Post
The PistenBully Tech support number is 775-857-5030
They should answer 24-7. Rod, Dave or Steve should answer.
Good Luck!
Ran all day today using the card but the tiller deck i had to manualy put down
What ended up being wrong with your cat
How much for your card
New problem not the tiller wont go up or down and it wont turn on . I can bypass it down the guage light comes on but no action any ideas. C
Conetion issue
The joystick does not work
There is a red light on the rear hydro card. Does thar mean there is a problem
. Rev. . Havent got that one it still works you need to turn to the right.
Have a PB270D doing the same. Some days it's better than others, Working on it. If you find anything out please post, I have been scratching my head for a while with ours.
