I'm compiling quite a list of part numbers specific to the Ford V4 engines in Imps, but stumped on one.
Does anyone know a part number or source for the oil pressure sender that activates my Actron oil pressure gauge? My gauge reads zip. Pulled the wire at the sender, grounded it, and the gauge pegs (well, almost at 90 psi) so I figure the gauge is OK.
Pulled the sender (sandwiched behind the mechanical fuel pump). Reads about 70 ohms on the bench and I can get it to drop to 50 ohms just by putting lung pressure blowing into the pin hole port. Sprayed some brakeclean into the hole - what little I could force in there - shook out some goo, and now can see some action on the gauge but no more than maybe 10 psi with engine running.
Hopefully a new sender will rectify...and hopefully I don't truly have low pressure indicative of nasty things like crapped out crank bearings and such. Not more than a couple run hours on brand new oil.
