The float switch to pump the effluent to the leach bed quit but the current load of laundry was enough to make things overflow.
The first effluent tank is pretty clogged. Getting it cleaned out today. Hoping this fixes my issue.
Question: Being as the tank is clogged and water backed up into the house, do wax rings on toilets seal from water coming up from the pipe? It has the plastic flange which directs flow from the toilet down. Is the wax ring for a total, waterproof seal or is it "mostly" sealed but the wax itself is mainly to stop gases from the system from coming up (same function as a trap)?
