Hey Folks,
I'm soon to be making a set of rock guards for my Thiokol. Just did a "repair" to the drop box, these have been dragged over god knows what. Or maybe this is just normal but I certainly don't think so. Just finished replacing the pinion seal as it was leaking and found another leak at one of the bottom bolts of the drop box. I decided to go with JB Weld steel stick, a two part epoxy putty mix, to try a repair. I hope it works.
Anyway, due to the wear, I thought it would be good to install a little prevention.
What I am looking for is how they are mounted to the frame. Any and all suggestions are appreciated.
Enjoy the pictures.
ra
Product used:
Problem area:
Fixed?
This is the mounting bracket, It is bolted around the upper portion of the drop box and goes forward to the cross member mid bed area. Other than that, the rear has the pintle hitch mount.
Looking down at the diff. you can see the brackets and where they mount.
Enjoy the pictures.
ra
Product used:
Problem area:
Fixed?
