Cowboy
Wait for it.
Its been awhile since I have had to put up a celing in a garage and insulate it, if I remember right you use a faced insulation facing down against the sheetrock. Is that correct or can you use an unfaced fiberglass insulation?
The garage is 24'x32' & I am only replacing a 24'x 14' area of the ceiling. My other question is can you put either thin plastic or a vapor barrier on the bottom of the rafters first, then insulate it before putting the sheetrock up or would that possibly cause moisture on the sheetrock. ? BTW. The garage will be heated, and the attic has gable vents on both ends.
The reason I am asking is because I do all of my own work and would like to get the ceiling insulated now, I have been down in the back the last few weeks and might not be able to put the sheetrock up for a few more weeks. Any thoughts would be appreciated.
