New York Tucker
mr addict, just prefect for you, never be a grouser short again. so, what are you waiting for, you can be there in a new york minute.
Turns our I am allergic to rubber tracked Tuckers. Rubber wheels no so much. What would I have to talk about and work on if I didn't have severely distressed pontoon roller Tuckers? Actually the answer is more money but the joy from worn tracks is priceless!
Plus would that be any example to set for 4 month old Jovan Tucker?
guess, one grouser short, is far better than, having no followers on the forums, we love all your issues and problems, fine example you set
Next generation with track addiction in his DNA will carry on the pontoon legacy!
I will take 2 tracks and rubber over 4 tracks and steel any day just don't have that much time to play with a grease gun.
tried grooming with two tracks on narrow trails in heavy wet snow conditions and losing traction in sharp corners with no options of where else to turn - leaving bumps in the most dangerous locations possible, or spending time shoveling the bumps off the trail, time much preferred to be spent somewhere else - decided 4 tracks all under power is the way I want to go
Then you should give four tracks & rubber a shot. You may not go back to 2 tracks!
some day if I were to get one a sedan model would be the way I would go with a 6b cummins and a taller gear set the 4 track idea just screams speed and for s&r or tours would be the cats ass if I could get speeds in excess of 25 mph on a packed trail
