If you put them in masonry fireplaces I hope you ran a pipe up the chimney. The colder masonry chimney will cool the exhaust and creosote will form quick.
Good point Muleman. But... depending on the insert installed, won't the efficient "burn' taking place take care of that?
The fireplaces are the manufactured type with triple-wall pipe. I inserted a 6" liner (Olympia Forever Flex) inside that with new stainless steel offset on the bottom and capping on top.If you put them in masonry fireplaces I hope you ran a pipe up the chimney. The colder masonry chimney will cool the exhaust and creosote will form quick.
I have several acres of woods (all hardwoods) so I can't see going to coal since I have an endless supply of wood. The only woods that will see these stoves is oak, cherry, maple and ash.One ton of coal is about three and a half cords of spruce firewood. To buy that now it is about 200 to 300 dollars a cord to buy. Coal on the other hand is about $65 a ton, and it takes about five tons to heat a 3,800 sf house for the winter, in winters that hit -50 and colder at times.
Not a clue to why people got away from coal at the prices of other heat sources.....
The wood stove that I replaced would have burned those same 8 logs and would have hardly anything left come morning. It's 25-degrees out and the stoves kept the house warm enough that the furnace never kicked on, heating about 3400 sq/ft with lots of windows, cathedral ceilings....The fireplaces are the manufactured type with triple-wall pipe. I inserted a 6" liner (Olympia Forever Flex) inside that with new stainless steel offset on the bottom and capping on top.
I put 4 relatively small at approx. 6" diameter logs in each last night about 10:00. When I went to get them going this morning, there was still parts of the logs as well as a nice bed of still-red coals.The wood stove that I replaced would have burned those same 8 logs and would have hardly anything left come morning. It's 25-degrees out and the stoves kept the house warm enough that the furnace never kicked on, heating about 3400 sq/ft with lots of windows, cathedral ceilings....
You're thinking about it right...
What's your current pipe size going up?
You're looking for a flange at the bottom of the pipe (top of the stove) to connect the stove to the new liner. Do you have an insert or is it a free-standing stove (how hard is it to get to where the existing pipe meets the stove)?
What's the diameter of the outlet on your stove? What's the diameter of your innermost pipe (of the existing triple-wall)?
Bill, Steve... Is he going to be looking for something like a Flush Stove Adapter DSP Double Wall 6in Stove Pipe
. Sorry for highjacking your thread with all the questions & pics .
I'm going to have to defer to thcri and muleman on how best to adapt a liner to the stove as they're a couple of our resident experts... You're probably going to need a new cap as well (since the one you have is set for 8" and a new liner will be smaller diameter). I'm also guessing that you may have to remove and/or replace that damper.
I guess if I was in your shoes, I'd start by asking what's an acceptable temperature and such on the exterior of your pipe as that seems to be your concern but the temp may be OK after all.
Are you talking 13 face cord or full cord? If I had to do 13 full cord a year, I'd move... I can cut/split/stack about 6 face cord (2 full cord) in a weekend. It would be more if I didn't have to cut it so small so it'll fit in the insert(s) but I need to cut at approx. 16" lengths and small enough to grab with a single gloved hand. I burn about 5 full cord/year but that may go up since I'll be tempted to run 2 stoves at a time.Having the wood on the property is a hard agument against going to coal. My issue is that to cut and stack about 13+- Cords of wood, would take a great deal of time and effort. Where I can get the required amount of coal in an Saturday afternoon. Can haul about two tons in the pickup at a time so it works out much easier for me. Still have a few cords of birch and spuce cut and stacked in case of an emergency out of the weather though.
Again, check with thcri, muleman and our other resident experts but check your cap up on top of the chimney. As I was instructed, your capping should be such that air can flow between all the walls of the piping to the outside (and the innermost is where you have your rain cap). On the plate/pan looking things I was mentioning earlier, I have them raised/vented so air can escape/move through those triple walls. If yours are covered such that they're not getting any ventilation, it may cause some raised temperatures.But even with a really hot fire in it I can lay my hand on the outer pipe upstairs & not get burnt but it just seems hotter then I thought the triple wall pipe should be on the outside but I have nothing to compare it to .![]()
A face cord is 4' high x 8' long, only one row of 16-18" pieces.
(One of the three rows that make a "full" cord.)
The coal idea sounds very intriguing. What are you burning the coal in?
Cowboy, Most triple wall pipe will over time suffer a little degradation about 2-3 inches from the top of each section. The insulation installed in the sections settles and shrinks a small amount. If you can lay your hand on it and there are no visible leaks it is probably still ok to use. If it had been seriously overheated from a chimney fire then it is more likely to need replaced. The flex liners are great and do offer a seamless pipe for better draft and safety. The toughest part is getting the flex attached to whatever it is venting. If you have 8 inch now I would not drop below 7 for the type of fireplace you have. If your house is very tightly insulated you may have draft troubles if you downsize it. Does your current triplewall have standoff plates keeping it centered in the cavity it runs in?
