I'm currently being quoted a "zero mile" engine for $US 3700. Includes the following, running with time based guarantee.
brand new case, German crankshaft & balanced VW rods, Steel backed main bearings, rod bearings, & double thrust cam bearings, reground cam & German lifters, new 85.5 balanced piston kit, quality rebuilt single port heads with new valves, guides & 3 angle valve job. Rebuilt flywheel and German gland nut. Good used single port tins, shroud, new oil cooler, new 12 volt alternator with internal regulator so you can eliminate your external voltage regulator. New 09 distributor, and Bosch 12 volt coil. I can also full-flow the case and oil pump so you can run an external oil filter.
At this point cash is easier to come by than time. The locals feel good about this shop.
Other than the $$$ any downsides?
Cidertom
