Bamby
My Sears Kenmore Dishwasher has developed issues, mainly it refuses to run well maybe I should say run as designed. It's kicking on and off and short cycling in it's attempt to function.
I removed and gutted the inside all the way down to the grinding mechanism and removed all the accumulated debris that was hidden down in there and attempted to run it again, without any success.
Next up was to open up the dishwasher door to expose the brains of the unit itself. When I had the main control board exposed to view even though the dishwasher itself was "cold" I could feel or detect heat from the component so I'm feeling it's probably failed.
So off to googleland to source a replacement control board for replacing it and actually sourced another concern "FIRE". It seems that there is a pretty good history of these boards "failing" and starting "fires". [FONT=arial,helvetica]
Problem:
KitchenAid, Sears Kenmore, Whirlpool dishwasher fires (all manufactured by Whirlpool).
Product design/defect causes predictable opportunity for control circuit board failure leading to fire.
Please note: because we have reports of repaired dishwashers catching fire a 2nd time (and more), we do not recommend replacement of the control board as a safe solution.
Source of Above
Now after reviewing the information in the article above I'm wondering about fixing the thing. It would be far cheaper to fix rather than replace and would any replacement actually be any better or safer, heck they still may be utilizing the same board for all I know, but I do know if I do fix it I'll never again start the thing and head off to work or whatever and leave it unattended while it's running.
[/FONT]
Problem:
Source of Above
[/FONT]
and ours is probably closer to ten than five so it's outlived it designated lifespan already, so I didn't pursue or push the issue why bother
