utahwilson
Figured that would get your attention. Need some help here. The bottom nut on the variator steering adjustment bracket is Frozen to the bolt. I have tried heat, leverage, impact, phuemantic chisel with hammer and not budge. I am afraid If I put too much torque I will bust the bolt. How screwed am I is I release the spring so I can cut the bolt out if needed and replace with a new bolt?
Second question, once I get this fixed. When I put it back together should the nut be turned all the way in so the spring is compressed and then back off counter-clockwise since this is the bottom? Same with the top. Was not clear in variator tuning instructions or I didn't follow.
thanks…the is the only piece left to have her running.
