Muskeg Tractor
how610
Does anyone know if there is an adapter available to mate a small block GM to the original bell housing with a standard 3 spd trans on an original 1966 318 Muskeg??
i'm assuming that it has a removable bell housing if so it's a matter of finding the right bell housing mixing and matching clutch disc and presure plate and the proper pilot bearing i would keep a 318 or a 360 with a holey 2 barrel on it the old chrysler motors were bullet proof and long running motors once you got rid of the plastic timing gears also the old chrysler electronic ignition was plenty reliable some times a balast resistor could go bad on mine i mounted 2 side by side but never had to use it. same for the control modules
