Down a bunch of threads, I described burning up the hydraulic pump. I've put in a replacement, plumbed in a relief valve since the new pump did not have one. I've got pressure in the inlet hose to the control valve (I can watch it twitch when I engage the valve), but no cylinders budge at all.
Any ideas?
The control valve has terrible access and about ten hoses. I cannot read a brand name on it.
My original problem was very weak, shuddering cylinder movement, then none.
Do I have a total airlock? Is that possible? Do you bleed these things? How?
Thanks.
Any ideas?
Thanks.
