Ok , its time to start the Mattracks installation on the mini mini van. This morning I washed it off and took it to the shop. Pulled the front wheels off and was able to get one side on the front lift kit installed. It was much easier than the Suzuki. After jacking it up and removing the front tires.
1- Remove the 3 nuts holding the top of the strut in place on the body.
2- Remove the bottom bolt where the strut attaches the spindle and push down and pull out at the same time, this gives access to the top of the strut outside the fender well.
3- compress the spring and remove the center nut on the top strut mount. remove the the nut then the mounting plate ( be careful there are washers and spacers to drop and loose ) remove the spring.
4- the new spring is then installed, it went in easily with minimal compression of the spring.
5- After installing the top mount back on the strut add the new 3" spacer to the top and orient the plate as shown in the picture, The slot in the top is how you correct the castor and camber after adding the spacer, then reinstall the bottom bolt that holds the strut to the spindle.
One side took about an hour. Next I will do the other side and then move to the rear.
