master cylinder
shovanl
dose anyone have a NAPA crossover number for a master cylinder thiokol spyte 1977 thiokol#1222027. Thanks LarryS
The kit for a 59 Ford 3/4 or 1 ton is the best info I can give you right now. The kit should fit the cylinder as best I can recall. Look at the pic in the NAPA book and see if your cylinder appears the same........
I do not have my LMC parts book handy to check to see if your cylinder part number is the same as the LMC........
Larry, 1222027 is NAPA #14021 and uses rebuild Kit #1.
Your slave cyls. ship tommorow, I'll PM you the tracking number.
-Pat
Thanks Pat I rebult the old master an had to take a lot out of it to get read of the rust and as you can gust it leaks. thanks for the part # and will look for the slaves from you Thanks agian Larry S
