Looking for 1987 LMC 3700c RF spindle assembly
bottle washer
Looking for just the spindle assembly. The tensioner is still good. This one has the little plastic wheel on the other side of the arm. Would be great to get the bearings also... any info would be great!! 315-725-3659
Im guessing you have the short 1/2 an axle. and you needed the stub.
were they able to save the flexi part of the assembly and just bore out the old spindle?
The threads had broken off the spindle, clean break... they drilled and threaded the spindle and used a stud screwed into it and then welded. Seems to be working as intended.
