Any and ALL Builders
I just bought my first cat. LMC 3700c groomer. With 12 person cab. Going through the cat right now 12 way blade is off drag is removed and de tracked today. The cats in overall decent shape. Motor runs great installing new electronics cleaning up wiring full service on the 3208 install 4 new rubber filled tires and packed all 10 wheel bearings. The track rubber is shot and has mis matched sprockets. Degreased whole cat and didn't find many leaks. Hydraulic fluid look good. Tracks have 78 gr was wanting to cut down on the tracks from 3 8in drive belts and 2 4in powder belts and just get ride of one of the power belts to get the cat to around 12 foot 2" wide instead of 13' 10" any thoughts. The cat will be used for back county skiing and tours and also vehicle recovery and some remote access construction. Please let me know if there's anything I have left out and any things that i should look out for on this cat as weak spot's so I can fix now. Thanks again Chad I use the cat in the Serria Nevada's in California elevation is 7k-10k
