Inquisitive
I am seeking advice, etc... regarding fixing a broken / torn track 'in the field' (broken down, in the snow).
www.fallline.com
With problems you seem to be havingI think if anything you want your idler tires foam-filled as a priority over the bogies. The bogies won't affect track tension, but the front idlers will. You need a consistent and reliable opposing pressure from the front tires to the track, so that when you set your track tensioners it holds that tension (for a while). Some older model Thiokols actually used the pneumatic front idlers to partly set the track tension (more tire pressure = tighter tracks), and though you could probably do that, it is not necessarily how the track tension on the 1500 is designed to work.
