The kristi have 8 forward gears I believe . I would have to look at my KT3 to be sure . Its been awhile ......
I have not seen a Kristy that could do 20 miles and hour unless it was down hill towing a Snot Tract or Puckered Tucker
Not sure they could pull a 2000 pound load but I have seen them pulling snow grooming equipment. The transmission in a KT3 is all Kristi built and if you break it ,parts are hard to find .
The tilt system works from hydrualic rams front and rear . You can level the body for running sidehill without worry of spilling your Mai Tai
They have been known to throw exhaust fumes in the cab and this can be fixed by building a better exhaust header set up , as i did on my KT3 rebuild that I posted .
Still , its much better than riding around in a "crushed tin can" (Snot Trac) made for a 4'3" midget .
