KITTEN FIRING/WIRING ORDER
GYPSY
I've lost my sketch of the order of the plug wires on the distributor cap and spark plugs on my Tucker 222 Kitten with a Ford Anglia 100E engine. Can anyone help with a sketch or picture?
Thanks
THANKS!! I assume that they are counted from the front spark plug (radiator). Do you know how they are "counted" on the distributor cap? Man I hate it when I don't make a sketch and even more when I do and lose it.
Assuming the rotor in the distributor turns clockwise set the timing marks in line with each other on the "crank pulley". #1 piston should be all the way up . Put a screw driver in #1 spark hole and you should feel the top of the piston . Where the rotor cap points is #1 .
