JS72 window wanted
YukonDean
A big steel roller fell on my 1985 JS72 cab. It broke the front window.
Does anyone have a replacement window.
Thanks
Thanks
Something does not seem correct with your year and what model is it?
jS72 means it's a 1972 model could be a 48" wide unit a 54" wide unit a 64" wide unit respectively the cabs are the same on the 48" and 54" but different on the 64" unit
Thanks for the reply
The unit is a work unit and I am not up on these sort of things
Picture looks like a J5 if you were to measure from side to side it should measure
64-65" we just have them made a the local glass shop they should be made from 2 ply laminated if you were to take your old one in even if cracked it could be used as a template if its qbroke beyond taking it in then make a template from cardboard of the opening and tell them the thickness of the rubber trim
