JS-72, probably a J5 it is 64" across the body.
I used it a lot this spring with no issues, then a track broke.
That is fixed but it will not engage the motor to the tracks.
I think it is the clutch, as it will go but real very slow after clutch release and only in first and second. It does not even draw down the motor.
I had a mechanic look at it. He has never worker on these before but thinks the clutch is no good. He believes there is no more travel in the mechanism but did not look farther at the clutch itself.
A crane hit it in on the front and did quite a bit of damage including the windscreen and put a 6" dent on the roof. I don't know if that could have affected the drivetrain.
Very odd that it worked fine, then a few months later, after sitting, the clutch is not useable.
Any ideas on how to check? Does the engine have to come out to do the clutch.
It has a 300 Ford engine i believe.
Thanks from the Yukon.
Dean
Dean
