journal liners
redsqwrl
GOLD FF Supporter
I keep replacement sleeves and journal liners on hand.
they are in east central WI
they are less than $400 an assembly
I am a teacher.
My buyer will not need these yesterday they will need them in an upcoming scheduled maint session.
Installation available.
complete turn key diffs available
empty banjos rebuilt.
I buy them in bulk. these kits are not plug and play. If you can not:
read a dial caliper.
stretch a string or borrow a laser alignment tool
weld
do simple math
safely operate a grinder
these assemblies are not for you.
If you posses common sense and a can do attitude
they are very easy to install and shim to square. if you are a terra track guy don't kid yourself. this is the kit you must do.
If you are a steel grouser rubber belt guy the tinfoil HVAC tape will work for a short bit.
the key to all of the above is jacking your rig up when you grease it, and locate grease zirks where they do some good.
A limited amount are on hand at any time. I am like rust. steady and slow.
:walking gator:
Mike
there is a thread here where someone was inquiring. hopefully they find this
