buckle97
We live in an old house, with old windows and doors, with little insulation, and it gets cold! We have window AC units for the summer and have no problem getting the house cool enough for our tastes. Any heat that builds up in the house goes right out the windows
. We have propane space heaters and electric space heaters as our only heat source. I guess our biggest problem is that we don't leave any heat or air on when we are not there. For instance, we both work 8-5 M-F and there is no air movement in the house during those times. My wife turns on the air when she gets home from work, it's pretty cool when I get home, and then we turn it off when we go to bed. The heat is really a bigger deal. It will typically dip into the low 50's and even the upper 40's in the house during the day. My wife gets home at 5 and fires up the heaters, but it takes them forever to get a room even comfortable, let alone warm. Are we crazy for not leaving any heat on during the day? I guess we are mostly afraid of the space heaters starting a fire while we aren't there. Last winter was the first year we left them on while sleeping. I know replacing the windows and doors, adding more insulation, etc. will help, but it still won't keep the house that warm.
My real question is: Is it your opinion that central heat and air will provide enough benefit to outweigh the cost?
Another question: Do you leave electric or propane space heaters on while you aren't home?
. We have propane space heaters and electric space heaters as our only heat source. I guess our biggest problem is that we don't leave any heat or air on when we are not there. For instance, we both work 8-5 M-F and there is no air movement in the house during those times. My wife turns on the air when she gets home from work, it's pretty cool when I get home, and then we turn it off when we go to bed. The heat is really a bigger deal. It will typically dip into the low 50's and even the upper 40's in the house during the day. My wife gets home at 5 and fires up the heaters, but it takes them forever to get a room even comfortable, let alone warm. Are we crazy for not leaving any heat on during the day? I guess we are mostly afraid of the space heaters starting a fire while we aren't there. Last winter was the first year we left them on while sleeping. I know replacing the windows and doors, adding more insulation, etc. will help, but it still won't keep the house that warm.My real question is: Is it your opinion that central heat and air will provide enough benefit to outweigh the cost?
