I know Dargo just installed a hardwood floor in his bedroom but he didn't post a step-by-step installation thread. I'm considering installing some wood flooring in our dining room, probably after the holiday season is over (so maybe spring '07).
I'm curious about installing 3/4" thick hardwood floor. Do you rip up the baseboards and reinstall them over the floor? What about the door frames? Do you cut the door frames and slide the floor under the frames? Any advice?
She had her heart set on Bamboo, but then saw Brazilian Koa, also called Tigerwood or Goncalo Alves.
She wants wide planks (5" or 5.5" width). Is there any advantage to wide over narrow planks? It seems like the wide planks would be easier for me to install, but unfortunately cost more than narrow planks.
Do the home centers rent the flooring hammers? If not, where do I rent one of those? BTW, Tigerwood is substantially harder than Oak, are their air powered/air assist flooring hammers that can be rented? On the hardness scales, Tigerwood is 170% as hard as red oak (2160 on the Janka scale vs. 1260 for red oak). Any advice on installing this stuff would be greatly appreciated.
