brianf - Thanks for the reply. I was thinking along that same line, and I checked into Pinto parts. You are right. Many are available and will fit this engine. The problem for me is that the starter and clutch fork are reversed. That is the clutch fork is on the drivers side on the Pinto, which would make it on the right hand ( wrong ) side of the Bombi and visa-versa for the starter. Not that I really care where the starter is, but routing the clutch cable from the front left of the Bombi to the right rear side of the tub may be a lost cause. I would most likely have to go hydraulic at that point. As far as repairing the bell housing that I have, the crack is better described as a break. The original cast-into-the-bell housing boss that served to stabilize the end of the guide sheath for the clutch cable was broken off prior to my purchase of the machine. Along with the mounting boss, the critical cast in thick rim of the housing is also gone. The cable and the broken off boss were not with the machine when I got it and the person I bought it from is no longer available. This would mean fabricating and welding a suitable replacement to the damaged and quite thin section of the bell housing. The "fabbed" part would most likely be of a different material than cast making the joining of the two dis-similar materials a less than desirable joint. Not that it couldn't be done, just risky in terms of durability. Long walks home in bad weather are way low on my list. More to my liking is the comfort of a stock part. Sorry for the length of the reply here, but I'm trying to get the job done so I don't have to look back. I hate re-doing a job.
