Hi Everyone,
I have an Imp 1404 from the late 1960's that now has (3) flat tires. I finally got around to attempting to remove the wheels yesterday when I ran into some issues. I jacked up the rear of the Imp 1404 on 'solid' gravel ground. I removed the wheel nut's and washer's from the two ends of the leaf springs. I then removed the almost seized but definitely bent (2) 'C' shaped hangars from the outside of the leaf spring. I then attempted to remove the last remaining nut holding the leaf spring on to the square cross-bar. I created a round nut. Is this 'nut' the only thing left to remove to take the outside leaf spring off the Imp 1404 and remove the two wheels?
