Identify an Engine for a Museum
Re: Identify and Engine for a Museum
I think it is a Fairchild air craft engine that is upside down from it's running postition...
I may have seen one of these recently at the Iowa State fair in an old engine exibit. If it were not this engine it is remarkably similar...
Hows this ?
You guys are amazing, thank you so much, this thing has been the subject of much rumour ;)
One more favor....
Since this is for the Museum up here in the Yukon and we are working bit by on providence, is there a database or paid service where we can confirm the specific plane it belonged to ? Does NAVCAN or FAA have this capacity maybe ?
This appears not to go back too far. http://registry.faa.gov/aircraftinquiry/country_inquiry.aspx
Thanks
Chris
BTW,
The engine I am familiar with here has a crank start feature I had not seen before. You crack a crank to wind up a spring, then trip a release to use the spring to spin the engine. The engine here started up instanly at an idle....
The Wiki links has a list of military training aircraft this engine was used in back when.. I think I would start by eliminating those down to your most likely candidate. Good luck.
