I have no idea what this is called
ddrane2115
Charter Member
I need to aerate, chop up, loosen up, and get a seed bed for grass. Tilling is too much, but I know there is something that can pulled behind that will just rough up the top of ground, leaving it smooth. I have heard of people using old box springs, but I dont think this will work in my hard pac soil.
dont need big, bx 23 is all I have to pull it.
Help my ignorance
Landscape rake without guide wheels. That is what I use.
BigAl started a thread on PASTURE RENOVATION, I posted a more detailed response in that thread. But your situation sounds like you want to do a similar thing on a smaller scale.
Forget pulling a landscape rake with a BX23 unless you break up the soil first. The only thing that will happen is that it will dig in and then stop the tractor dead in its tracks. I know, because I have a landscape rake and a BX22, and have tried this. All it has to do is catch on one root, and you are dead in the water. Rent a tiller first and get the soil loose, then use the rake to get out the branches and rocks. It will also smooth the ground as it does its job...
How large of an area do you need to do?
How about a disk harrow? There's several on e-bay that are "relatively" close or many local tractor places may sell or rent.
Renting a Harley Rake would work wonders.
Here's what I do, did yesterday and doing today especially if you have hard pack. I have similar conditions ................
Use a disk harrow set approximately to a depth of 2"-4", I recommend making multiple passes.
Rake without wheels.
It really does work well without having to operate a slow tiller on a BX (bucking bronco!). Disk work better when ya go fast ............. :17875:
:respect:
I have both implements, 6 1/2' disk and 7' rake.......... your welcome to use them .............. :beer:
note: Yeah, I know it's a BX and it was just a little attempt at humor!
I was not wanting to go more than 1 or 2 inches deep at most. I have a 48 inch tiller for the bx, but too much for what I want to do.
disc may be it, the but harley rake is what I think I mean........anyone have a pic
thanks guys
I am thinking disc harrow may be for what I want. How much should I expect to pay for the biggest thing I could pull with my bx? I am guessing something 48" in width, one or two sets of discs.
If you've got a 3-point hitch and PTO, a Harley Box Rake could be the ticket. It's got a rotating drum with teeth that will tear loose the top layer of soil and redistribute it.
OK, I am so not looking far enough. This is what I am talking about, TSC calls it a drag harrow. My question is will this rough up the soil enough to allow seeding, then possibly covering it back. I have some manure I can mix in also.
Nope. I have one. It won't tear up the soil much. It's great for levelling and breaking up clods of soil but it only lightly scratches the surface of existing turf/pasture. Maybe if you drag it around for 20 times or so it will scratch the surface more but it will take a while.
Harley rakes are very expensive and rare to find for rental. As Junk said they also need some serious horse power.
My proposal for a harley rake rental included having someone else do it.
Around here, many are attached to a skidsteer.
HERE is probably one of the least expensive disk harrows.
How about an arena ripper? Click here
PB, how would that do on grassy areas that I want to smooth out from gopher and mole holes. As for the seed bed, only need quarter to half inch depth. I am also thinking way over kill for a dethatcher.
If the mole holes are fresh then it will rake them out after a few passes. It's great for breaking up clods of manure and dirt.
A dethatcher isn't going to do much either.
I top-dressed an area of my yard this year and used the chain harrow to smooth it all out once I spread most of it around with a shovel and rake.
I tried using it to rough up some bald spots but it didn't work so great.
It depends on how much you want to "re-do" your lawn. If you are just overseeding it then maybe you could rent a plug aerator and really go to town on it. Then throw some seed out and maybe drag the chain harrow around to level out any mounds.
The chain harrow/drag is a nice tool to have but it's just one part of the whole job.
we have one soil here, clay! I will be mixing some cow patties in before tilling to make it finally grow
thanks guys
If it is mostly clay, then mix in lots of sand to provide drainage and to "fluff" the "soil" so the roots can take hold...
When I researched this a few years ago they actually recommended against mixing sand with clay as it just makes the whole mess harder.
The recommendation I had was that organic matter (cow patties) was better when trying to amend clay soil.
Since you are tilling it up you can also add Gypsum which is supposed to bind with the clay and provide better drainage and deeper roots for the grass. You should be able to find Gypsum at Lowes or Home Despot.
Has anyone ever used a chipper to grind up drywall? Seems like that might work ??
My chipper is pretty small but I did think of it. If I had a bigger chipper then I would have tried it.
My tiller is pretty big and I know it will work.
I just finished burning up the remains of 55 Douglas Firs and just had all the plumbing in my house replaced so I have lots of Drywall and lots of acidic soil!
:tiphat:
Help my ignorance
This will also do the trick ...
