I just picked up a Lite-Foot (Pistenbully Scout) snowcat. It has the following components.
I'm not a mechanical retard (lots of experience rebuilding motos), but I've never worked on hydrostatic systems, so I'm looking for insight.
Here's what I think one would do to flush the system.
- Sauer series 90 pump
- Volvo F11 final drive
- Auburn Gear hubs
- Drain reservoir
- Drain pump
- Drain hoses at final drives
- Keep everything clean!
- Replace both filters
- Fill pump at upper access
- Fill reservoir
- Turn motor over with coil removed (30 sec)
- Repeat above step and check reservoir level
- Keep pressure gauge attached to M3 port, repeat above steps until spec'd pressure is obtained.
- Check reservoir level, fill as needed.
- Start engine, slowly cycle drives forward/backward for several minutes to remove air.
- Recheck reservoir level.
