I need some thoughts/advise.
I'm looking at a building and wondering if I should replace the HVAC. The building and pics are in this thread.
http://www.forumsforums.com/3_9/showthread.php?t=66
I'm looking at all the components of the existing system and the potential (probable) maintenance related to all this "stuff". For my needs, I believe it's overkill since I won't need to filter for chemical, biological or nuclear agents, cool massive amounts of electronic components, etc. The current HVAC equipment also uses approx. 3500-4000 sq/ft of space which I'd like to use for other things.
The building itself needs very little heat or A/C as the temperature is pretty constant (about 68 in the summer and I hear probably 60 in the winter).
I do want to have a bit of HVAC but my main thing is to keep the humidity down. There's no visible mold or mildew but it smells musty. This may be from the fact no HVAC has been run at all for at least 10 years and the fact that a couple doors have been open to the outside which may have let moisture in.
So, what would be a good approach? I understand that someone should be brought in to "size" things properly but I'm wondering if they'll be scratching their heads as well due to the unique nature of the building. I would like to get the humidity down then close it up tight to see if it's coming from the outside or from within.
Thoughts?
Brian
Thoughts?
Brian
