hub and hub pulley
jakers
Looking for a hub and hub pulley assembly. st4 part number 3-12945. Mine broke and we are out of commission with over 6 feet of snow and no transportations. Can someone help???
I see nothing by that part number need to know what pulley you need the snow trac numbers all start with st than the part numbers im thinking this is a vw part or something added drive accessory's like extra fans or hydraulic pump
on the rear wheel hub the flange that the tire bolts to is only pressed on the hub. i pressed it back on and tack welded mine.
mine was a 6 mile walk with the tire and hub.
but the "hub and pully" He is asking about doesn't fit that description.
yes I have done that too it was also about 6 miles for me I need to know if it is a six stud hub or a 5 stud type I might have an extra 5 hole but no 6 holes
I believe the 6 lug bolt pattern is very close to the standard 6 lug Chevy pattern that many trailer axles use. Wouldn't take much to figure something out that way if you had access to one and the welder/tools to make it fit.
