johnday said:
Bob; Really like that fountain myself.
Gives me an idea of what I'd like to do upnorth. Could you give a blow by blow account of how you did it?
As stated before, I designed it, but I didn't build it. I had a kid with a strong back and a study shovel do the digging and he set the stone. But this is how it was done:
The fountain is a very simple design. Dig a hole about 24" across by about 32" deep and set in a plastic pump basin. The basins are available for sale from places that sell fountian and pond supplies. It looks like a giant size bucket.
The hole must be a few inches deeper than the basin because you need to slope the ground around the basin so that any water that sprays up and is blown by the wind eventually drains back into the basin.
After the basin is set into the ground, and firmed into place, you take a piece of pond membrane and cut it into a circle about 6' in diameter. In the center of the circle you cut a circular hole about 16" in diameter (make the hole several inches
smaller than the diameter of your basin so you can slit the hole and glue it to the top/sides of your basin to keep it secure).
Install the pump and the spray rose so that the rose is held slightly above ground level. Install a cap over the basin which has slots or holes in it, it is available at the pond/fountain supplier.
Go to your local stone yard and buy a bunch of flat stones in the color of your choice. In my case it is a flagstone with rust-brown veins but bluestone or any other flat stone could be used to suit your landscape design. You will have to break some of the stones into the desired shape. I helped set the stones the
second time they were set because while I
thought I explained what I wanted before going to work one morning when I got home I found something that did not have the look I wanted when I got home!
Standing the stones on edge create a ring around the fountain rose - make the center hole large enough to get the pump out for the winter!!!
At least those are the instructions I gave the kid!
Surround the large stones with crushed stone, pea gravel, etc. The wire for the fountian runs under the stone to your power souce, I have a switched waterproof outlet on my wall so the power cord runs to my wall and is simply plugged into the outlet. A lightswitch controls the outlet, when we want the fountain on we just flip a switch.
I used stones that were roughly the shape of a triangle with the high point in the center of the fountain, but you could make the fountain in any design that would suit you. I think square stones would make for a great look too. You could reverse the stones I used to alter the look so that the lowest point of the stones was at the center and the stones high point was around the perimeter. The fountain is a bit over 2' tall and close to 4' in diameter. The fountain could be made larger or smaller to fit your space.
You can see that we have some flagstone used as a walkway around the fountain, this is necessare because just outside of the view of the photo are a couple of rough hewn limestone benches. The benches allow for a nice sitting area, although we never actually sit on them. The fountain & benches are about 30' away from our patio where we have comfortable chairs. We consider the benches more of a visual accessory than a practical seating area.
All of our landscaping is
very informal with touches of formality added in for interest. This area is the exception to our overall landscaping and is rather formal compared to the rest of the property. We think the fountain works really well to break up the formality of the Japanese style stone garden area. It adds informality into formality. I think it works well for us.
I should also note that the fountain can run dry if winds are strong or you don't get enough rain. Water will be lost due to evaporation, the sun heats up the stones so you may find the need to add 5 gallons of water as often as every 3 or 4 days. We had a drought this summer so I was watering the new weeping cherry that you can see behind the fountain, the runoff kept the fountain full this year. But I suspect if anyone builds a fountain like this and it is exposed to wind and or full sun you'd want to have a hose close buy to refil the basin.
