Homemade Trailers
mungo45
Hi, I am looking to buy a homemade trailer from an independent seller. He does not know what the trailers GVW is. How to you determine what the GVW is of a perticular trailer. It is a dual axel 8x16 deckover.
any help is appreciated
Are you going to register it for road use?
If so, check with your DMV. They normally require a couple inspections to determine the GVWR as well as road-worthiness.
At 16', you're right on the cusp of what needs to be inspected. In PA (where I am), any homemade trailer over 16' needs inspection by either the Sheriff's department or State Police.
I don't know where you are but in PA
Even with a homemade trailer the trailer needs to be registered, to obtain a registration it would need to have a declared GVW. There is no way to license a homemade trailer (that I know of) without it being registered.
The GVW of the trailer will depend on the axles, 2 3500# axles would be a 7000# GVW, 2 5000# axles yield a 10,000# GVW. Subtract the weight of the trailer to determine the load capacity. A 16' trailer will likely weigh 1500# to 1800#. Tires also determin the weight capacity, check those! One fairly common trick is to use cheap tires, so you may think you have a 10,000# GVW trailer but only have tires that can hold 7000#. Each tire will have a capacity molded near the bead.
B_Skurka said:
The GVW of the trailer will depend on the axles...
Also, the frame and coupler size will be checked to determine capacity.
If it has a 2" coupler, they probably won't give you more than 5000#. A 2 5/16" will be required for the 7-10K# rating.
I don't the specs on the frame but I'm thinking the main beams on a 7K# trailer are 6" and they're 8" for a 10K# trailer.
