Home Heating Question
pirate_girl
legendary ⚓
FF Patron
I keep the temp at around 71 during the day and at 64 at night.
My thermostat has settings for heat-(auto, on or fan).
I've always kept it on auto for heat.
Is this right?
I finally cleaned the furnace part of the system of dust and replaced the filters last night, so it's comfortable in here now.
Auto (for my system at least) means that it will automatically switch from A/C to Heat to maintain the set temperature. I switch to heat for heat and A/C for A/C and have really never used the "auto" mode.
On the recommendation of my heating installer I usually leave the "fan" on during heating and heavy A/C use to keep the air circulating and filtered. I always leave the fan on when running my wood burning fireplace. This will distribute the heat throughout the house.
Yes on is it. Then it will only come on when it gets below the setting you have it set at.
Just did that, and it kept running far longer than when I had it on auto, so I just set the temp back to 62 and put it back on auto and now I can't hear it running constantly.. the motor on the furnace stopped.
Where's Murph, I leave mine in auto too. I'd like to know if it is recommended to leave the fan on continuously?
You want to leave it on Auto PG :wink: . On or fan are for when you want it to run constantly & it bypasses the temp setting .
Sure if your not paying the electric bill , I cant imagine anyone else recomending leaving the fan on constantly other then the power company or someone that sells the fan motors :biggrin:
Most T-stats the on position is for fan only. That will make the fan run independent of where any other switch is set. Auto will allow it to run the fan and the a/c or heat depending on which you select. Auto is fine for most all situations. I run my fan only to equalize temps in all the rooms when we are having bright sunny days as the sun side warms a lot more than the back side of the house. You can post a pic of the T-stat for further clarification but your setup is a typical downdraft Miller furnace is it not?
Correct, Muley. Now, to contradict my esteemed colleague, Cowboy, there is a very good argument for leaving the fan motor running, even when the heat plant or a/c compressor are not running, and that is to prevent stratification throughout the home, particularly in the Summer when temps get very warm. I leave my fan motor running when the a/c is on, and find that my compressor runs significantly less frequently, even on the hottest of days, than when the system is on automatic. I don't consider the electric bill to be any higher than normal summer usage, but I do know that the house is a lot more comfortable both upstairs and downstairs (I have a 2,600 sq. ft. colonial). That being said, I also adjust my heat run dampers at the change of seasons so more of the volume is going UPSTAIRS in the Summer, and the opposite in the Winter. We also run our ceiling fans in reverse in the Winter to circulate the warm air that hugs the ceiling. I don't worry if the electric bill changes $5-$10 if I'm running these motors, because I feel my comfort is worth it. I'm sure I piss away more money than that each month on stupid stuff. Oh, I also have a new, backup furnace blower motor in a box next to the furnace should I need to replace it. I also have a new backup sump pump as well. These are important to me, as both items seem to fail on Sunday afternoon or during the night, both times when you pay a premium for the repairman, and when it's impossible to get parts.
Correct, Muley. Now, to contradict my esteemed colleague, Cowboy, there is a very good argument for leaving the fan motor running, even when the heat plant or a/c compressor are not running, and that is to prevent stratification throughout the home, particularly in the Summer when temps get very warm. I leave my fan motor running when the a/c is on, and find that my compressor runs significantly less frequently, even on the hottest of days, than when the system is on automatic. I don't consider the electric bill to be any higher than normal summer usage, but I do know that the house is a lot more comfortable both upstairs and downstairs (I have a 2,600 sq. ft. colonial). That being said, I also adjust my heat run dampers at the change of seasons so more of the volume is going UPSTAIRS in the Summer, and the opposite in the Winter. We also run our ceiling fans in reverse in the Winter to circulate the warm air that hugs the ceiling. I don't worry if the electric bill changes $5-$10 if I'm running these motors, because I feel my comfort is worth it. I'm sure I piss away more money than that each month on stupid stuff. Oh, I also have a new, backup furnace blower motor in a box next to the furnace should I need to replace it. I also have a new backup sump pump as well. These are important to me, as both items seem to fail on Sunday afternoon or during the night, both times when you pay a premium for the repairman.
Yep , All Great info & well stated Jev . No disagreement from me other then it really depends on the type & size of the house & familys needs .
In your case that makes perfectlly good sense & probably would apply to most folks here that live in larger houses & have more then two occupants . Where in my case its just the wife & I & She,s only home half of the time I rarely run heat or air unless she is home & mainly for her comfort . I prefer fresh air with windows & screen windows open on the front & rear doors . But our house is shaded by big 100 year old trees so cooling in the summers not much of an issue unless its 100 degree outside temps , Winter same thing since we have a fireplace .
Our house is extremely well insulated even being the older part is 100 years old or better it wont get below 40 degrees in the dead of winter with no power if its kept closed up . I know this as a few years ago a bad ice storm I was without power for 7 days & I never even used the fireplace as my wife was on a working cruise in the bahamas & I was home all by my lonesome clearing debree & downed trees & limbs , 40 degrees felt very comfortable to me when I came in for the evenings :biggrin:
Good idea on the backup blower fan & sump pump as well , I also keep a brand new spare water heater in the basement as well . :wink:
You're a hardy soul, Cowboy. I get out my generator when the power goes out. Call me a sissy city boy, but the older I get the more I like my creature comforts. I can run the entire house off my unit, except the a/c. We use the low amp draw ceiling fans in place of a/c when under generator power.
PG, from a photo of your home I believe the Auto setting would serve you better, especially if you have a separate Heat/Cool switch.
that's a good idea as a young home ower in anchorage i lost a water heater on thanksgiving and a blower motor on christmas eave good thing i had a buddy who was a plumber he got me the stuff too keep me going other wise i'd have been waiting till the following monday to get repair items.
I leave my fan on all the time (at low speed). I finished the basement and with the fan air blowing, I don't have to run a dehumidifier.
I'm going to throw something out since nobody else mentioned it. I don't think you should be lowering your heat setting so much at night. It's going to take more energy to re-heat it then to have kept it warmer for the duration. I'd maybe lower it to 66 or 67 but nothing lower. If you have electric heat, it's really going to take a hit as your heat-strips kick in to raise the temp back up.
Yeah, I am so looking forward to my first heating bill.. NOT!
During all that horrible, unrelenting heat we had, the cooling bills killed me.
Mine is a Carrier unit with the variable speed DC motor on the fan. I was told this is an extremely low energy consumer to leave run and it is designed to run continuously for years.
Yep, doesn't take a whole lot to cool or heat my little saltine box, but I just wanted to clarify if I was doing it right this year after having the entire unit replaced for a first winter for heating properly.
The auto setting is doing just fine.:flowers:
Don't you burn natural gas? They are predicting a 20% increase in gas around here to try to get NY to open up the drilling in the Marcellus shale.
If it gets too cold, I'll put on a sweater and so will Gretchen.
I'd rather go broke cooling the place than heating it.
I'll be fine.
I guess thermostats are different around the country. Auto means if you set it at 70.. and it falls to 65.. turn the heat on. If it goes to 75, turn on the AC. Now there is also a fan option. That would just run the fan continuously.
The Auto / On setting is for Your fan only . It won't turn on Your heat ,or AC . The top switch on Your T-stat does that .
I leave mine in the On position for the most part . It seems to help circulate the air better .
Mine is on Heat/Auto and that's where it's going to stay.
Thank you very much everyone, I appreciate the advice.
We're warm, and it's working just fine. ;)
Took me long enough, didn't it?
Sometimes I don't know what I'd do without you goons giving me man type advice.
Sure I have outside sources who look after me, but it's nice to have some guidance here every once in a while.
God knows I appreciate second opinions.
:D
