Hog trailer to snocat trailer?
snowbird
Any opinions on the wisdom of converting my old 5th wheel 6/20 hog trailer into a snotrac trailer? :mellow: I know I'd need to make a pair of "risers" to get the snotrac above the wheels since it's only 6 feet between them. I'm not sure how much structural stength is built into the sides so if I converted it into sort of a flatbed the gooseneck hitch wouldn't be strong enough?
Snowbird,
I would be very afraid to do this. the sidewalls and the roof and bows are structural, and removing them without adding considerable steel under the floor and to the frame woud be required. Could be done, but I don't think it would be cost effective....Maybe trade it off?
Thanks for the input. I'd suspected the trailer would be weakened without the sidewalls. Maybe I could salvage the axles at least. There's probably not much demand for a used hog trailer.:sad:
If you figure that you need a deck over due to the width of most snowcats, you would have to construct a new floor level above the tires and it just ain't worth it!!
Although, a second floor might put the strength back in???? Still too much work!!!
You just need to find a hog farmer with a deck over for sale!!
I would bring the trailer to a metal fab shop & tell them what your plans are, they should be capable to answer your questions. I think the major structural frame is already there in the floor & goose neck. Just my 2 cents worth.
OT.
