airdale
I finally got all the infor I needed to time the V4....the right front piston is #1...6 deg BTDC and I can see the marks so I turned the distributer and the pully mark rotated toward the marks on the block...the engine started running smooth and faster RPM, but I don't know where to stop. I assume that the pointer is TDC and the pully marks should be set at 6 block marks to its right but there aren't 6 marks so are the marks 2 deg each? seemed that the farther the pully mark went past the TDC mark the faster the enging ran. HELP?
