Ok guys, I want everything you know about grapples. Primary use will be brush and trees. Bucket or root? Brand sugesstions and experience? Got pictures of yours? What size (60"-72") for my heavy Kioti DK45s? Tires are loaded (880#) and I'll use a HD BB for counter weight (700#). I'm done pi$$ing around with all this chit I got round here from the timbering and the well............ . This is what I've looked at............WR Long, AnBo, Borgford, QA, Addington, Piranha, Luden, Workforce
SpecificationEngineEngine Model4A220LXBEngine Gross Power45 hp(33.6kw) Rated Speed2600 rpm No. of Cylinder4 Fuel TypeDiesel AspirationNatural Displacement134.1cu.in.(2197cc) Fuel Tank Capacity15.3 gal(58 L) Pre-heating SystemGlow plugs TransmissionTransmission TypeManual ShuttleSynchronized Main GearSynchronized No. of Travel Speed Forward/Reverse12F/12R Min. Travel Speed of Forward w/ Ag1 @ Engine rated speed0.24 mph Max. Travel Speed of Forward w/ Ag1 @ Engine rated speed17.32 mph Power Take-OffPTO TypeHyd. Independent PTO Power34 hp(25kw) Rear PTO Speeds(1st)540 rpm @ 2507 Engine rpm Rear PTO Speeds(2nd)N/A Mid PTO SpeedsN/A Front PTO SpeedsSame as Engine Speed Brakes and ClutchBrakesWet Disc ClutchDry Single Plate Dimensions w/ AG TireLength w/ 3-point hitch127.7" (3242mm) Width61.5" (1564mm) Height from Top of ROPS101.9" Height from Top of ROPS Cab91.9" Height from Top of ROPS FoldedFrom Top of the Highest PointWheelbase74" (1880mm) Ground Clearance14.6" (370mm) Front Tread Ag Tires - Min47.5" (1208mm) Front Tread Ag Tires - MaxRear Tread Ag Tires - Min39.9" (1014mm) Rear Tread Ag Tires - MaxTurning Radius w/ Brake88" (2680mm) Turning Radius w/o BrakeHydraulicsTotal Pump Flow14.2 gpm Main Pump Capacity9.9gpm(14.4cc/rev) Power Steering Pump Capacity4.3gpm(6.3cc/rev)
3-Point HitchStandard Category (Optional Category)1(2) Lift Capacity, 24" aft of hitch, lb(kg)2654lbs.(1204kg) Control TypePosition,Draft and Mixed
WeightWeight w/ Ag Tires w/ ROPS4299lb (1950kg) Weight w/ Ag Tires w/ Cab4585lb (2080kg)
