I am having problems with the manual Fuel pump on my 81 Bombi with the 1600 engine. Replaced the pump last yr and just replaced it again. I now realize that it's not the pump. Is there something on the cam lob that fails
and then no longer moves the pump arm? I looked inside the fuel pump hole (as best I could) and could not see anything. But that only means I could not see anything. I am thinking I should just put a electric pump on and take off the manual pump
Any ides or suggestions?
The Bombi is half covered in 9 feet of snow at 7,000 feet in the High Sierras . Thought I could fix it with a new pump put after spending a few hours laying on the snow with my head in the engine compartment I relized that the pump was not the problem.
Thanks
Phil
Thanks
Phil
,,,,very funny to see but proved the pump had lots of suction ,, that was a rotary vacum pump on a dzl engine but the principle should be the same ....
