Koyker 155 front end loader the rear lift arms lift fast and strong do not bleed down front in loader once it's up does not bleed down curl works perfect however the lift is very slow and weak if I place the bucket flat on the ground and curled down the lift arms come up it will not lift the tractor off the ground I've checked hoses no leaks change filter everything looks good nobody has time to work on a call Yorker lifter around here or won't help me diagnose the problem any ideas before I Drive it off and dump it in the pond
