A nun was sitting at the airport, waiting for her flight to Chicago . She looked over in the corner and saw one of those weight vending machines that tells your fortune and thought to herself, "I'll give it a try and see what it tells me."
She went over to the machine, stepped up on the scale and put her nickel in. Out came a card that read, "You are a nun, you weigh 128 lbs., and you are going to Chicago ."
The nun sat back down. She told herself that the machine probably gives the same card to everyone. The more she thought about it, the more curious she got, so she decided to try it again. She went back to the machine and again put her nickel in, and out came a card that read, "You are a nun, you weigh 128 lbs., you are going to Chicago and you are going to play a fiddle."
The nun says to herself, "I know that is wrong, I have never played a musical instrument even once in my life." She sat back down. From out of nowhere a cowboy came over and sat down, putting his fiddle case in the seat between them. Without thinking, she opened the cowboy's case, took out the fiddle, and started playing beautiful music. Surprised at what she had done, she looked over at the machine, thinking, "This is incredible, I've got to try this again."
Back to the machine she went, put in another nickel, and another card came out. It read, "You are a nun, you weigh 128 lbs., you are going Chicago and you are going to break wind."
Now she knows the machine is wrong, as she thought to herself, "I've never broken wind in public a single time in my life", but getting down off the scale, she slipped, and as she was straining to keep herself from falling to the floor, she broke wind.
Absolutely stunned, she sat back down and looked at the machine. She said to herself, this is truly remarkable! I have got to try this again. "
She went back to the machine, put in another nickel, and another card came out. It read, "You are a nun, you weigh 128 lbs., you have fiddled farted around and missed your flight to Chicago!"
