BigAl
I have recently ran into a small problem of my KT3 snowcat draining the battery when it sits a couple days . I really don't want to put in a battery shutoff switch but actually find the drain problem .I guess this procedure can be used for any car , truck , or a snowcat in my case that you suspect a problem and it is not the battery itself going bad . What I do to start with is take off the positive cable and then use my meter to connect between the battery cable and the + post of the battery . It will give me a readout number in amps of the drain . it should read zero .
In my case everything should be dead when the key is in the off position . Then I disconnect one fuse (Lights, Dome lite switch , ignition , etc ) at a time until the meter reads zero .
