Door Weather Stripping
NorthernRedneck
Where's the best place to get replacement weatherstripping that goes around the door of a snowcat. The stuff on our lamtrac is all colapsed and the doors rattle like crazy which drives me crazy after about 8-10 hrs of a steady run. I put some foam tape around the cab where the doors seat last season and adjusted the door latches to try and lessen the doors rattling and it helped a bit but it's time for new weatherstripping.
Need engine compartment insulation. Anyone have a cheap idea?
Mike , I have 8 rolls of 6'x40' of Metal building insulation that is the same as the stuff in my KT3 . It has a reinforced plastic on one side and foil on the other . About 1 1/2 " thick . I think it would work fine . Any metal building contractor should have some left over pieces you can buy or I'll give you some .
