BigAl
I call it stain sanding . It helps to really spread a nice finish on whatever you are staining .I developed this technique after not getting the desired affect I wanted on some furniture I was building .
I sanded my new Tresle table , I am building , to a 320 grit .Then I stain it . I then take a air driven disc sander and start going over the freshly applied stain . You will go through some sand paper !!! What happens is the sanded stain shows every imperfection in the wood . I then continue sanding to get the desired results for the finish . A light brushing of another coat of stain is applied, wiped clean and allowed to dry . Followed by 3 coats of sprayed on clear finish . Sanding with 600 grit between coats and hand rubbed with super fine 0000 steel wool after the final coat .
I'll grab some pictures when it's all reassembled .
I probably have about 30 hours of time in the building and finish of the table and bench . The lumber is a local pine , kiln dried . I used 15 - 2"x6"x10' to completely build this table and bench . That works out at under $75 !!! Tables of this quality cost about $1800-$2000 to purchase in the furniture store !
