This looks like a Tucker in decent condition. It is certainly not restored, but it is not junk either. Opening bid is $3500. There is no reserve.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=160049889611&fromMakeTrack=true
[FONT=Arial, Helvetica, Verdana, sans-serif][SIZE=-1][/SIZE][/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif] Vehicle Description [/FONT]
1953 Tucker Sno-Cat model 743
This unit has a V8 330ci Chrylser hemi industrial power plant. It has a 24 volt electrical system with a new starter, starter switch, and new batteries. The brake system has just had new fluid and bled out so they are operational. It has an automatic transmission (fluidmatic drive) with high / low and reverse gears, which is fully operational. Lights work. All the track rollers and cleats are in good condition.The drivers side rear pontoon needs to have a roller guide strip welded onto each side on the bottom. There are many pieces of steel reinforcing welded onto the frame as you can see in one of the photos. This unit runs very well. It is being sold as is with no warranty being expressed or implied.If you would like to view the cat before bidding just email me so we can set up a time.If you have any questions please ask, hopefully i can answer and if not i'll try and find out. Payment will be required within 5 days of auction close. Sno-Cat may be picked up anytime after payment clears. It can be stored untill you can arrange to get it picked up. This is pick up only and NO SHIPPING will be paid by the seller. Good luck bidding and thanks for looking !
