dzalphakilo
Banned
Taking a couple days off.
Took longer than thought.
Replacing Lennox Pulse furnace with a 14 SEER variable speed heat pump, along with a set of gas logs for the fireplace (couldn't justify spending the money for a variable speed two stage gas furnace for back up heat in North Carolina).
House is on a slope, took longer to build a foundation for the outdoor unit to do it right this time.
Putting in a whole house dehumidfier tomorrow which should prove interesting.
Also have to run to a buddies shop to pick up a 4' drill bit for the fireplace (longer length than I thought) along with a pipe threader.
Two condensing units are removed. The one, the three ton A/C (being replaced) and the other which was from the third floor that I did two years ago but was too lazy to remove at the time (the replacement unit for the third floor was moved to the other side of the house to reduce the linset run).
